Exercise & Fitness Logo
maurice van kuijck Posted on Jan 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a precor efx 546 v3. battery 12v 12Ah yuasa is dead. there is a difference in voltage?
  • maurice van kuijck
    maurice van kuijck Jan 18, 2019
    at the charging port there is 18v displayed
Kelvin Irons
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Jan 19, 2019
Kelvin Irons
Expert
Level 2:
New Friend:
Answers
57
Questions
Helped
9173
Points
175
If it can be recharged it needs to be but only on a trickle charge over a lone time even a week at very low amps like 1 or 2 no more than 6 amps good luck
    maurice van kuijck Jan 19, 2019
    i bought a new battery 12v 12Ah but at the charging port it says 18v?
5 Related Answers
Anonymous
  • Posted on Apr 19, 2009
SOURCE: Precor EFX 546 elliptcal shuts off
Your problem is most likely due to the magnetic sensor on the right side of the unit under the plastic housing.
The right pedal arm, has a magnet emeded in the on the inboard side of the arm. When the arm comes around and passes this sensor at the bottom of the unit, a pulse is generated and sent to the computer.
The mangetic sensor on the frame of the unit, may need to be adjusted to a closer proximity with the pedal arm magnet. Assure the arm does not strike the magnetic sensor however.
It's also possible the sensor has come loose and fallen into the base of the unit.
Anonymous
  • Posted on Mar 04, 2010
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Megasom
  • 699 Answers
  • Posted on Aug 01, 2010
SOURCE: new battery
A lower capacity battery (12v 8Ah) can/should preferrably be replaced by a better capacity (12v 12Ah), and usually more expensive, quality battery of the same voltage with higher amperage rating: it will in general take longer to charge but will also last longer in usage.
Please make sure that you fully charge and discharge your new battery pack a few times to 'condition' it.
Hope it helps and have fun!
Anonymous
  • 710 Answers
  • Posted on May 11, 2011
SOURCE: Hi, I was hoping to
Hi Tim,
To get you started, here is the webpage for the manual for Precor 546v3
I'm still working on the other one. Check back if I don't have it posted when you read this.
Handie Andie
adamfjeld
Adam Fjeld
  • 1508 Answers
  • Posted on Jun 14, 2012
SOURCE: I need a new battery for my granddaughter's John
you can order a new one here www.powerwheelsoutlet.com
What causes a slow boot up on a Precor EFX 546?
A slow boot up on a Precor EFX 546 elliptical machine can be caused by several factors, including:
  1. Low battery voltage: If the battery voltage is low, the machine may take longer to boot up. This can be due to a weak or old battery, or a problem with the battery charger.
  2. Dirty or corroded contacts: Dirt, dust, or corrosion on the battery contacts or other electrical contacts can interfere with the machine's ability to start up quickly.
  3. Faulty console or display board: If the console or display board is malfunctioning, it may take longer for the machine to boot up or may not boot up at all.
  4. Loose or damaged cables or connections: Loose or damaged cables or connections can prevent the machine from starting up properly and may cause a slow boot up.
  5. Outdated software: If the software on the machine is outdated, it may take longer for the machine to boot up or it may not start up at all.
To troubleshoot a slow boot up on a Precor EFX 546, you can try the following steps:
  1. Check the battery voltage and replace the battery if necessary.
  2. Clean the contacts on the battery and other electrical components.
  3. Inspect the cables and connections for damage or looseness.
  4. Check for any error codes or messages on the console or display board and consult the user manual for troubleshooting steps.
  5. Check for any available software updates and install them if necessary.
If none of these steps resolve the issue, you may need to contact a professional technician for further assistance.
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
2answers
What kind of battery do i need for efx 546?
There a few possible options for the battery. This link will take you to all of them. Please have your serial number ready to help narrow your choices.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
Precor efx 546 wobbles when raising incline
It may be either the front shroud is installed incorrectly or broken, or the corkscrew for the incline motor is bent. If it is bent, it would need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
4helpful
Battery low
The battery is not fully charging to the 12v requirement their are a couple of screws that hold the side panels then rotate the panels counter-clockwise and they will come off. Take the battery leads off use a multi-meter the voltage on battery if it is below 12v then replace it. You may purchase this from a Precor dealer in you area if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you.
1helpful
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
