Computers & Internet Logo
s
sirefyu_adam Posted on Jan 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
D-link dwr-921 can not connect to internet
I inserted a sim card but the device won't connect to internet. I've tried to manually configure the apn settings and time to no avail.
Kelvin Irons
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Jan 19, 2019
Kelvin Irons
Expert
Level 2:
New Friend:
Answers
57
Questions
Helped
9181
Points
175
You have to try turning the hole lot off and restarting it i had this problem with putting mine and same with printers good luck should work
1 Related Answer
David
  • 470 Answers
  • Posted on Feb 08, 2015
SOURCE: my dvr H.264 16ch offline since i bought it.Every cable is connected from the dvr to router d-link 3G wifi dwr-113 and internet is avaible in the Vodacom modem i use.i don't have adsl at home so i use
Do you ha e a router with a firewall?
DWR-113 router, how do I change the password so others can't connect to it?
Here is the manual:
http://files.dlink.com.au/Products/DWR-113/Manuals/DWR-113_A1_Manual_v1.01(WW).pdf
Activate sim card
You should check you network service for the Apn they use. You may have to insert the apn on the tablet to get the data
One sim will work in the D-link DWR-730 firn but when I put in another sim that is working fine in another device, it won't work. I can log onto the d-link but you cannot get onto the web
I do have the same problem. All works fine except it stays "disconnected" and no way to change that.
Also I found no way to put or change the number to be dialled in the DWR-730 to connect to a service. Normally it needs to dial *99# for the operator I am using. I guess our problem is only that.
Who from Dlink can tell us how to access the modems dial string?
3answers
How to use aircel sim in my datacard ?
You can contact customer care to get the procedure for datacard activation for your sim.
6helpful
2answers
I want to use my airtel sim in my beetel data card please tell me config & dial no. in orissa state
You'll need to configure the Internet Access Point Name (APN) of Airtel into one profile of your data card, the dial number for a cellular modem (data card) commonly is *99#, the APN data of Airtel could be requested to the following link: https://www.airtelusainc.com/Contactus.aspx , but before a simple test you can do to check if your data card can handle the Airtel SIM card is inserting it into the data card and launch its connection manager, if the software shows invalid SIM or similar message, it means your data card is locked or tied to Beetel SIM cards, but if it shows Airtel header and a good signal level you'll only have to input the mentioned data above.
2answers
I want to connect mmx 310g modem by tata docomo but it does not work
hello,
I ve purchased one mmx310g datacard but in that data card there is no configuration setting of docomo & stel.kindly help me
1helpful
How to open the GPRS of chinaphone
creating data accounts:
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
This configuration is working perfectly using ZT321, Baizhao 8928 and IPhone Clone A380 and probably will work using other China Phones.
If your SIM card is previously activated using other phones specially those phones supported by Globe and Smart, no need to activate your SIM. This is also valid for postpaid users since SIM cards are pre-activated for MMS, GPRS and other services.
But if your SIM is not yet activated or never been used for MMS and GPRS, you need to activate your SIM before you can use MMS and GPRS services.
For Smart SIM, you can use your China Phones to activate MMS and GPRS by simply sending/texting MMS ON / GPRS ON to 333 (I don?t know if this number is still valid). No need to download the configuration for Smart. Just use the configuration I?ve given.
For Globe SIM, this is a little bit harder and need some workaround. I tried to call Globe Customer Service but they cannot activate your SIM manually on their system and the only way to activate it is by downloading the configuration thru text or by asking them to send the configuration. But since China Phones are not yet supported by any Service Provider, what you can do is to active MMS and GPRS using another phone. Monitor until your SIM is activated then transfer your SIM in your China Phone and enjoy surfing and sending MMS.
In another forum, they said you can try using configuration for SE p900. I?ve never tried this but if this really works, well and good for China Phone fanatics.
3helpful
3answers
Iphone wont connect to internet and it is unlocked, Also will not download itunes
check your mobile internet settings in: settings general - network - data connection
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
