Nokia 3310 Cellular Phone Logo
Brenda Beere Posted on Jan 18, 2019
Just bought a Nokia 3310 classic. have received texts from 02 & friends on different networks but the most important person in my life is with 02 but cannot send me texts. can you help, please.
5 Related Answers
Anonymous
  • Posted on Feb 15, 2008
SOURCE: i can send my text messages but i can't recieved any text messages in all networks
hi!
the Message Centre Number With my Network Provider is correct, i have excellent connection..
thank you so much fo ryour time..
Anonymous
  • 7752 Answers
  • Posted on Jun 13, 2008
SOURCE: no text with lg shine-send or receive
you need to check the msg center number on your phone.
So call you provider and have them give you the msg number
Anonymous
  • Posted on Jul 19, 2009
SOURCE: I can't send text messages with my Cricket Motorola Q
Hey, I just bought the same phone from ebay, and it was preflashed for cricket too. My phone had the same exact problem. I called cricket technical support at 1-800-274-2538 and they refreshed my flashing while i was on the phone with them. As soon as I got off the phone with them my phone worked perfectly. I hope this helps! - Alyssa
Anonymous
  • 403 Answers
  • Posted on Oct 16, 2009
SOURCE: I have a samsung a777. I cant receive or send
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/at-t-phones/SGH-A777EGAATT/index.idx?pagetype=prd_detail&tab=support
Check out the section on Messaging page 65 in your manual:
Important!: When creating a message, adding an image, a sound file, or a video clip to a text message changes the message from a text
message to a multimedia message.
Important!: Adding an image, a sound file, or a video clip to a text message changes the message from a text message to a multimedia
message. This also changes the Options that appear in this menu.
Note: A multimedia message should only be sent to a phone which can
support the receipt and display of this message type.
Note: If you exit from this View screen, you will need to go to the Messaging ➔ Inbox screen, the Recent Calls screen, or you will need to dial your Voicemail contact to access your messages.
Note: Messages can also be accessed by navigating to your Inbox (Menu ➔ Messaging ➔ Inbox).
Messaging Settings page 72 in your manual:
You can set up various options for using messaging services.
1. When the Idle screen displays, press the Menu soft key,
then select Messaging ➔ Messaging Settings.
2. Select the type of message settings that you want to
change.
• Text Message
• Multimedia Message
• Voice Mail
• Push Message
• Broadcast Message (SIM card dependent)
3. Press the Select soft key or the key.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Anonymous
  • 274 Answers
  • Posted on Apr 14, 2010
SOURCE: N5530 -Cannot send and receive text messages
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Cant recieve calls or texts.
As you said.... doesn't appear to be a cellular phone network problem.
Review all your settings
Return to the store you bought this from & ask for some help in setting it up.
I can' not send masages
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
I am not getting mms from my freind in saudiarabia.can u help me please?
Do you receive MMS from other phones/friends ? Are you positive the problem is not from your friend`s network/phone ? Try these tips : 1.Ask him to try and send you MMS from a different Network in Saudi Arabia.
2. Punch :*#0000# and post me the information you see on your screen.
3helpful
I cannot receive multimedia mail. How do I get it to work?
here is a general procedure to understand how MMS works. In this procedure, a photo is being sent to another compatible phone.
  • Step one: Take a photo from your built-in camera phone or download via the Internet.
  • Step two: Personalize the text, graphics, audio or video clips.
  • Step three: Add recipients' number and send.
The recipient on the other side will receive a message alert. Once he opens the message, a picture message will appear on the screen. If there is any text, it will appear below the image. In case, you send MMS to a non-compatible cell phone - the recipient will a SMS with a default line, "You have been sent a picture message!"
There are many challenges that exist with MMS:
  • Adaptation of multimedia content: There may be a difference in the compatibility of multimedia content for different brands of cell phones. If the network operator is supporting your content adaptation - you can enjoy compatibility with more networks and vice versa.
  • Cell phone configuration: Multimedia Messaging Service requires some parameters to be correctly placed in you handset. Sometimes, due to poor configuration, you may not receive messages.
  • Bulk messaging: Sometimes, if you send MMS to a large number of subscribers, there might be some difficulty in sending messages. Now transactional overloads are being optimized.
Moreover, there are several similar terms such as Enhanced Messaging Service (EMS) - very similar to SMS (Short Messaging Service), allowing you to send or receive messages with some special text formatting options such as bold, color, sound effect, icons, etc.
Please rate me!
1helpful
2answers
I have just bought a nokia 2330 classic and put my old sim card in it..it works fine except that i cannot send texts but can receive them.do you know why this is?
it may be a problem of the msg. center number!! check it and then try and restore your phone to factory settings this might solve your problem!!
5helpful
8helpful
4answers
My nokia 6220 classic wont let me send my text messages
Hi all, I had this problem myself today- the unit receives and makes calls, receives texts but can't send them other than to the outbox.
Please try this first before taking it to the repair centre- I did a soft reset which means to restore factor settings of the unit with the sim card in (it doesn't work otherwise)
1. ** IMPORTANT**Save all your contacts and photos, etc your storage card first!!
2. Make sure the phone is on the general profile (as opposed to offline, silent or other) then type in *#7370# on the keypad. It will tell you that the phone will reset/restore settings. Click the 'ok' option when this prompt is on screen.
3. After that, you'll need to reset time, date etc. Then just copy all your contacts etc back over to the main phone and done!
Restricted phone lock nokia 3310
Restriction code, contact your network provider
When the operator buys the phone from Nokia,they restrict them to their networks inorder to protect their invest, hence the restriction.
If your phone was unlocked then, its possible to use different sim cards in there.
2answers
Text Messaging
That's a problem the Network Service Provider should be able to solve. I don't think it's your phone.
Remember to delete msgs, when you no longer need them. The phone only has a set amount of memory.
Phonebook 500 x 16 fields, Photocall
Call records 20 dialed, 20 received, 20 missed calls
Card slot microSD (TransFlash), up to 2GB, 64 MB card included - 6 MB internal memory
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
