SOURCE: need manual for singer 14u52a
You should also try www.sewusa.com. I found the manual for a used Necchi 521FB I brought. Hope that helps.
SOURCE: looking for manuel and sewing needle size for
Go to www.singerco.com and download a free manual. Be sure and save it on your computer and print it out so that you always have a copy.
SOURCE: I've just bought a Pfaff
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
SOURCE: how to put the tread in the needle of a 2732
the singer website has a PDF free manual download
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 2732 ) & click search
second one is free
Sounds like the motor might be having problems. I would take it in for a proper servicing.
