Information taken from owner manual.
Before operating the unit for the first time, or
after replacing the car battery or changing the
connections, you must reset the unit.
Detach the front panel (page 5) and press the
RESET button (page 6) with a pointed object,
such as a ball-point pen.
Note
Pressing the RESET button will erase the clock setting
and some stored contents.
SOURCE: Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
SOURCE: Installing Sony Explod CDX-GT170 CD deck
Red wire ignition, yellow wire constant hot, black is ground, the rest are speakers
SOURCE: I need a wiring diagram for the Sony explod
You can download the complete instruction manual in PDF format from Sony CDX-GT11W support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
