SOURCE: ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
SOURCE: error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
SOURCE: F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
