Question about Maytag Washing Machines
Front load maytag washer will not spin - Maytag Washing Machines
    Master:
  • Maytag Master
  • 713 Answers
On these units the most common problem is the motor brushes are worn down,a new set of brushes should do the trick, i have done many of these
Posted on Jan 19, 2019
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Could be a number of things. Belt, control board, door lock, bearings.
Posted on Jan 18, 2019
SOURCE:
  • 1122 Answers
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Posted on Jul 12, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
SOURCE: major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Posted on Jul 25, 2009
BIKER T
  • 909 Answers
SOURCE: Maytag Epic Z front loading washer spin cycle very loud
your bearings and seal need to be replaced.
Posted on Sep 21, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
The drum bearings may have failed , Or the spin motor winding in the motor burnt out ,
Or the selector switch contacts are not engaging in spin cycle
Jan 06, 2015 | Maytag Washing Machines
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
Maytag mah9700aww,will not spin(laundry soaking wet)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
,.,./l;
Mar 05, 2011 | Maytag Neptune MAH9700 Front Load Washer
Maytag MHW2000AWW will fill with water but not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag bravos wont spin out
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag frontload washer won't spin the water out
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Jun 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load washer not spinning correctly
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
