Question about Kenwood Food Mixers
Kenwood 265 mixer works intermittently, even when everything locked in place. Seems like a loose connection on start button. How can we fix this?
    Top Expert:
  • Kenwood Master
  • 54,189 Answers
Replacing the start button (switch) may work
Posted on Jan 19, 2019
3 Suggested Answers
SOURCE:
SOURCE: Kenwood Major Mixer
Thank you for your time. I contacted the Kenwood company in England.
Posted on Apr 06, 2008
defrankond
  • 66 Answers
SOURCE: Mixer stuck
You will have to have the transmission serviced. sounds like the gears were ground out. you can do the service work yourself its not to difficult.
Posted on May 05, 2008
How do l attach my liquidiser to my Kenwood mixer
It should just sit in place with a turn clockwise until locks.
Jul 01, 2018 | Kenwood Food Mixers
Kenwood prospero wont start
There are interlock switches on that unit so that it wont come on with out the attachments. One of them is bad or loose
Dec 02, 2013 | Kenwood Prospero Compact Km265 4.3 Litre...
Kenwood Chef KM400 motor speed is too slow
A failed SCR or triac will not always show visually any sign of failure. Chances are good that is all that is wrong. If mixer had been plugged in when it got wet, that is all it takes. Also check the transient voltage supressors if the chef has them. They would be identified on the circuit board. as TVS or MOV along with a number. Only number to use is the one on the component.
If you can find ratings for the old devices, just matching the basic ratings should do. Just guessing, but the SCRs should be 20 amp and 400 volt, If the old ones are a lower rating than my guess, there is no problem with using the higher ratings, if my guess is low, go with the original's ratings. Manufacturer of device does not matter as long as ratings are at least comparable.
Jan 19, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
Cant releace the dough hook from my kenwood chef. what can i do?
hi the lock nut on the shaft may have been loose allowing the shaft to screw into the dough hook you hve to unscrew the hook out of the shaft then unwind the nut down so you can release the shaft. other problems can occur if the retaining clip has unseated and jammed itself into the planet hub. this is more difficult and a kenwood agent would be consulted see www.kenwood.co.uk for nearest agent.
Feb 09, 2011 | Kenwood KM300 Chef Stand Mixer
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Kenwood Chef Restore
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Mixer part not rotating
Have recently inherited an old Kenwood Major A707A with same problem, contacted local electrical repair man, experienced with Kenwood mixers. He is fitting a new clutch, will cost about £30. I think its worth it. Anyone out there know where I can get Instruction Manual ?
Aug 14, 2008 | Kenwood Food Mixers
MIX7130
ship it back to anvil , buy a hobart ,best mixers in the world
May 19, 2008 | Anvil MIX7130 Stand Mixer
Kenwood Major Mixer
Apr 05, 2008 | Kenwood KM800 Major Classic Stand Mixer
SILLY QUESTION
Push the whisk attachment post up into the mixer, turn counter-clockwise and it should lock into position.
Apr 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Food Mixers Logo
102 people viewed this question
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
