Televison & Video Logo
A
Anonymous Posted on Jan 18, 2019
Battery chamberlain universal klik3u: I have replaced 3 times the battery by new ones during the last mont. It seems that remote is consuming energy without using it more than 1 click per day.
Level 3:
  • Universal Master 19,187 Answers
  • Posted on Jan 18, 2019
Universal Master
Level 3:
Answers
19187
Questions
0
Helped
4345010
Points
82261
There is very little that you can do about this except replace it. If it is new you may be able to get a warranty replacement. The internal parts are very small and contain chips.
5 Related Answers
Anonymous
  • 72 Answers
  • Posted on Nov 11, 2007
SOURCE: Which brand of universal remote control works for WEF2702 27" TV?
Try to call the phillips costumer service first!
Anonymous
  • 95 Answers
  • Posted on Feb 26, 2009
SOURCE: Viper Directed Electronics 479V Remote Gen 2
sounds like there is a problem with the remote itself. Your best bet is to purchase a new one and program it to the remote start
Anonymous
  • Posted on Apr 05, 2009
SOURCE: I lost my Comcast 3 in 1 remote. How do I get a
i need to progrem my tv for the volume i have a comcast
matney68
Donnie Matney
  • 426 Answers
  • Posted on Jun 25, 2009
SOURCE: replaced battery in remote even though old battery
• Resynchronization may be necessary due to the security method used by the remote keyless entry system. Resynchronization may be necessary due to the security method used by the remote keyless entry system.
The transmitter does not send the same signal twice to the remote control door lock receiver (RCDLR). • The RCDLR will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the RCDLR, perform the following steps: 1. Stand within 1.5 m (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds
kennyj67
kenny
  • Posted on Oct 10, 2014
SOURCE: My 2008 Jeep Wrangler Rubicon has starting
I have the same problem move the shifter to neutral and it starts every time I think its the neutral safty switch
Where is the "Learn" button on this model?
the learn button is on the motor unit
If then battery has to be replaced in the CLICKER key pad made by Chamberlin do you have to reset the code?
You should not have to reset the code. Simply remove the old battery and insert the new one, being careful to observe the polarity when you replace the new battery, and you should be good to go. The batteries can be obtained at most Wal-Marts, Radio Shacks and even through eBay if you know the correct number. Thay are lithium and will last a few years under normal use.
I have an older LiftMaster opener (1/3 Hp - 1991 vintage). I have had two older replacement universal type remotes that worked fine. Lately one of the remotes stopped working with the opener. Changed...
Hmm tricky situation try unplugging it for atleast 2 hours and remember any device usually handles one code at a time so if your using two remotes together with different codes that will happen thats pretty much all i can think of at moment
How to extend the battery life of your laptop HP/Compaq pavilion dm4
Tips to increase battry life:
1. Never charge when battery already full.
2. Keep low Brightness.
3. Keep volume medium.
4. Always use headset to hear songs or see films.
5. High graphics games never play on laptops it reduses your lapy's battery life.
6. Never use laptop up to 0% battery power.
7. Close background processes using task manager(these processes not essential but consume battary.
1helpful
I have a 2004 525i with aprpx. 24K miles. The problem is that from time to time something consumes the power from the battery during nights or day when the car is off for a long period of time. This is...
Your battery drain is due to the vehicle not able to enter sleep mode.A energy diagnosis must be performed,and you have to make sure you have the latest software installed.
8helpful
4answers
Battery its ctl1616 they said NO NEED FOR BATTERY CHANGE but it's not true. How many year this battery last?
The CTL 1616 is a special device.
It's not really a battery, but a "capacitor", which means, that it's mainly supplied by the energy of the light. The capacitor is designed to maintain the functions only for (short) periods of darkness.
It's NOT a "standard lithium battery", because It has a different voltage (2.3 V instead of 3 V) and consists of different materials.
Unfortunately, the capacitor loses its ability to store the energy over the time. So your watch may be able to maintain all the functions for more than 11 months of darkness in the BEGINNING, but after a few years it may only last for a few hours!
However this may be STRONGLY influenced by the use of the functions: for example the automatic reception of radio signals or using a digital compass may strain the energy seriously.
So, the use of different functions may affect the lifetime of a CTL 1616.
I also recommend to expose the watch to (bright) light as often as possible in order to maintain a HIGH level of stored energy.
I also heared that there were serious problems with the quality of this type of capacitor a few years ago. Maybe a new CTL 1616 will last for decades.
The remote for my Chamberlain Liftmaster Professional has been lost. I have a replacement universal remote but it won't seem to "learn" the new remote.
I WOULD RETURN THE NEW REMOTE - THE UNIVERSAL ONES ARE ALWAYS A PROBLEM. WRITE DOWN THE MODEL # AND FREQ. FOR YOUR UNIT AND BUY A UNIT MADE BY CHAMBERLAIN/LIFTMASTER FOR YOUR SYSTEM.
2answers
BackUPS cannot support during brownout.. is it a battery issue?
Yes it is a battery issue and you may have to contact either the vendor or manufacturer.
Warm regards,
Anirban Mazumdar
4answers
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
