Question about Karcher Garden
Kaercher window cleaner making screeching noise when switched on to use. What to do
3 Suggested Answers
SOURCE:
tech48
  • 624 Answers
SOURCE: cdn36 pbm
Does it make this noise only while playing a disc? or is it when it opens and closes.
If it happens while playing a disc, it could be the spindle motor or something rubbing on the disc while it is spinning. Since nothing is supposed to be rubbing on the disc, it would need to be taken apart and looked at while it is spinning to see what that is.
Let me know if I can help you any more,
Good luck,
Dave
Posted on Jul 01, 2008
rickead1
  • 1998 Answers
SOURCE: electric dryer makes a screeching noise while
could be your pulley or rollers or the motor itself you have to take the entire unit apart and visually inspect where the noise is coming from could be rear bearing if the model is old enough if you are not mechanical i suggest you call a tecnician hope this helps
Posted on Jul 15, 2010
I have a Samsung Tab A6 that keeps making a loud screeching noise And boots itself it was freezing the screen but when I factory reset it that seem to stop now it's just making the loud screeching noise...
Where did you get the phone from.?
I suggest you take it back to them & get your money back as a screeching sound is usually a network-lockout noise from a stolen phone.?
Best of luck.
Mar 09, 2018 | Samsung Tablets & eReaders
Making loud screeching noise
check drive belt driving altanator and air con it sounds like it needs adjusting
Dec 30, 2013 | Saab 900 Cars & Trucks
Screeching noise when starting
It sounds like the solenoid or starter may need to be replaced or both, which are usually sold together.
Oct 24, 2013 | 1A Auto Parts 1999 Oldsmobile Delta...
Hi, my dc07 cleaner has developed a very high pitch screech its not a constant sound but intermittent and last for a second or two and is very unpleasent, its a loud cleaner anyway but this noise is so...
hi.
it sounds like the bearings in the motor are worn out. the only solution is to change the motor, or the entire hoover. motors are available from ebay for about £35 and it will then need to be fitted. unfortunately these bearings do wear out eventually. once they start to make screeching noises like this, there is not much life left in them, and they will get worse rapidly.
if you decide to change the motor yourself, please feel free to ask for more details on how to do it.
hope this helps
Aug 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Screech noise from ps2 slim
Sounds like the laser may have gone bad on your system, try this - use compressed air to clean out the system, where the laser is, and other openings on the device. Then clean your game disc with a CD/Game Disc cleaner (bought at any gaming stores), try this. If this doesnt fix the problems then i would contact SONY and have them replace your system or atleast maybe they could try to fix it. Good Luck!
Jul 13, 2010 | Sony PlayStation 2 Slimline Console
My 2005 ford focus making screeching noise!
Serpentine belt , idler pulley bearing?
Jan 24, 2010 | 2005 Ford Focus
Rear Passenger Window Noise
sound like there is debris in the belt mouldings (the rubber strip on both sides of the window) usually caused by the outside moulding take a rag and clean it off see if that helps
Apr 27, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Spacesaver 1800XL Screeching or Grinding Noise
Is it possible that some spray cleaner got into the controls?
I always recommend that users spray cleaner on a soft cloth then wipe the control panel.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over itme, it may need to be manually dried or blown out.
But the keypad or control unit may be damaged.
Please post back with more details so we can help further.
Oct 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Cassette player works fine, then screeches after 20-30 minutes.
Yeppers very common problem .. If the noise dosent come from the speakers then the problem is in the motor in the cassette deck. if the problem comes from the speakers when the deck is playing a tape, then the problem is in the record/playback switch. you may beable to fix it by spraying just a lttle bit of tuner cleaner inside the switch. It shouldnt cost much to have a repair shop do this as if you spray too much your going to ruin the belts and the mechanism. Good Luck
Jul 31, 2006 | JVC UXN1 Shelf System
Garden Logo
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
