I changed the laser unite twice its running in another machine but in my machine still 110-0001 code is coming please reply as soon as possiable
Hi, i hope this helps goto page 225.
https://www.pcscopiers.com/pdf/canon%20ir-5075.pdf
regards
Testimonial: "I read already. its not useful, here error code is e110-0001. In google its shows change the laser unit or change the motherboard. I changed both. Again its showing like that. can you tell me whats the problem is? please reply asap. thanks."
Hi. If you replace the laser unit and the mother board ( I guess this last one is the image processor board, the one with the hard drive on it ) , you should try to replace the DC controller board.
SOURCE: Xerox Phaser 7700GX error 10
Check the left side door assy where the fuser is located, on the door near teh top towards the rear of teh printer there should be a piece that sticks out which will close a interlock swith when closed. It may be black or same color as teh covers. If this is broken off it will cause the problem you describe. Easy way to check is to use a screwdriver to push in on the interlock to close it and see if the problem goes away.
SOURCE: ir2016 canon xerox machine message error " downloading standby"
what is your erorcode please send me detailes
SOURCE: i have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
SOURCE: error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
