Cell Phones Logo
LaRon Twyman Posted on Jan 18, 2019
How to turn on english audio on xenon build? - Cell Phones
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
2answers
I only see a button on the dashboard that say check and its not changing it back to english
Extremely unlikely. Were you on empty or just put in a gallon or two of fuel? If you have a large tank and only put in a few dollars worth you might not see any change on the gauge.-----------------------------------------------------------------------------------------
Auto HID Xenon Light
On LG Xenon is it possible to move music files
you may contact the service provider.......
I cant changes it back to english
go to settings than go to more than the first thing on the top press on it than u can change it to English/ read the manual
UNLOCK LG XENON PHONE
Unlocking LG Xenon step by step:
-1 After turning on your mobile phone, press: *#865625#
-2 Press Yes to continue.
-3 Enter the 16 digit Subsidy Unlock Code
-4 Enter the 16 digit Subsidy Unlock Code again.
-5 Device should say: “Network Lock Deactivated”
My phone keeps turning off when ever i slide open
I have an lg xenon and it turns off ever time i go into the internet.
Crossover
i have lost my manual to the phoenix gold 600.1 xenon amp. i want to set it up by the book can you help me ?
Pheonix Gold Xenon 600.1 power problem.
Do your speakers move in/out smoothly if you push on them?
Have you tried disconnecting the speaker wires from the amp to see if it would remain on?
Phoenix gold xenon 600.1 power problem
Sometimes problems like this are caused by tiny strands of wire in the amp. These can cause catastrophic amplifier failure. If you pull the cover off of the amp, you should be able to see the strands (if they're present). If that's not the problem, you should send the amp back to PG for repair. Before you pull the cover, completely disconnect power from the amplifier.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
