Question about Hardware & Accessories
The loop that holds that band in place broke - Hardware & Accessories
  • 66 Answers
Grind the banana and apply it to the broken place. Let it dry.
Posted on Jan 18, 2019
2 Suggested Answers
SOURCE:
SOURCE: Watch Band Loop Missing
here ya go.
http://www.cdwplus.com/singleotherP.html
Jim
Posted on Apr 27, 2009
Small loop on band broke. Can it be replaced?
A jeweller can replace the whole band for another very inexpensively. Perhaps something a bit more exciting than black?
Jan 14, 2016 | Watches
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
The tension knob came off, have I broke it? Or just push down on the spring?
I am not sure though. Try to put in back in place. If it holds, then it's okay. Try to call the manufacturer and consult their tech rep on that.
May 16, 2013 | Saws
What muscles does the fit-loop exercise band work on?
Fit-loop exercise band is a type of exercise band that's used to work the lower body muscles: legs, hips, and glutes. If you're looking to target upper body muscles and core muscles as well, fit-loop exercise band is not for you and you should get a different type of exercise band (figure-8, fit tube).
Aug 20, 2012 | Exercise & Fitness
The clasp to connect mask to snorkle broke. can I purchase the small clasp?
In short, no. But just do as many other do and use a short rubber band. Lay the middle of the band across the inside of the strap, and then pass the snorkel tube through the two resulting loops either side of the strap.
May 21, 2010 | Speedo Condor Mask Snorkel Set
What I would love is for an EXPERT to solve a very small problem that exist with every Lap - Ironman style watch I have ever owned over the past 20 years. There is no exception!!! After about 1 to 1-1/2...
This is a common problem with all watches with rubber or leather straps, not just with Ironman. In fact, there isn't anything our experts can do, as the responsibility is entirely on watch band producers. We just can hope that when the nano technologies will develop to the higher level, there will be a possibility to produce brand new materials yet unknown to human. These materials will have no wear and tear at all and everyone will be happy with forever lasting bands, shoes, e.t.c. For a while we can only wait. By the way - if you will buy Casio, it will make no difference, as all watch straps are made by using same technologies and chemical formulae. One of my friends went very upset for the same reason as you, so, I did find a solution for him using piece of scrapped copper pipe. This is how you do that: Measure that small loop of your watch band and find or buy the piece of copper pipe of same size. Cut off 1cm piece of the pipe and file off any imperfections, then polish it if needed. Get an old leather belt, fold it into half and put the copper ring in between, then flatten it with hammer. Do it step by step, always checking that there is enough space for band and band end to go through the newly formed copper loop. When flattened enough, spray the loop with band matching paint and leave to dry. Respray if necessary. Now you are done and this loop will last very long time.
Rate me, plz.
Jan 11, 2010 | Timex Sports Ironman Triathlon 100-Lap...
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
1985 Silver Spirit. Gates 7270 belt to smog pump. Will not go over fan blades. Which bolts to romove to remove fan?
hold fan belt with both hands as if stretching a rubber band.place one end of belt over a fan blade all the way down to the hub.loop the other end over as many blades as length allows.''leap frog'' over remaining blades as necessary.if that doesn't do,there should be 4 bolts holding fan hub to it's mount on water pump spindle
Sep 26, 2009 | 2006 Rolls Royce Rolls Royce Silver Spirit
Watch band problem (Technomarine RSQL01)
Do you know no one takes proper responsibilities about electric item, but you should need to check once so Oniline sites are good because you can get a new stack watches. Top Seller of Week 10 Discounted Watches 24 7
Jun 23, 2008 | Watches
here ya go.
Jim
Jan 11, 2008 | Watches
Hardware & Accessories Logo
54 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
