SOURCE: IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
SOURCE: IBM WheelWriter 10 Series II not functioning.
Could be many things. Take off the case and look for parer clips, staples or other debris on or under the PC board or in the power supply.
DickyO
SOURCE: IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
SOURCE: IBM Wheelwriter 10 Series II beeps
either the carriage home position sensor flag is broken or the daisy wheel can't find home. try removing daisy wheel and re-installit. turn unit on and see if daisy wheel spins if it does then the carriage home position sensor has a problem.
Testimonial: "he knows his stuff"
SOURCE: IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
