My Asko w600 frontloader has an electric door release, which has just stopped working, with wet clothes inside. Any ideas?
Hi
First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door lock-switch assembly. If the door
lock-switch is also fine then the control board should be replaced. Hope this
helps...please post back for further assistance.
Daniel
It was my bad. The manual release didn't go because there was some water in the bottom. The hose was blocked and it couldn't drain. Doh.
