SOURCE: toro powerlite ccr model#38175
seems to me you have water or dirt in you carb pull the carb off take the bowl off clean it real good try to do so over a bowl or bucket to see the fuel that comes out to determine if its water or just dirt
SOURCE: what is the gas/oil mix for a Toro CCR 2450?
Hi my names Dane, and I'm going to help you.
The mix on the toro CCR 2450 is 50:1 I don't know if you;re having any more problems, but I wanted to include this link for you to check out. I'll let you judge.. Thanks! Dane
http://mattfleming.com/node/45
SOURCE: LEFT GAS IN SINCE LAST YEAR TORO CCR POWERLITE NO
Sounds to me that it leaked out.you might want to check the fuel line for leaks.
SOURCE: Toro CCR 2450, Common starting problems? Fresh
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
