What kind of casters are you installing? There are two types, ones that have a shaft sticking up from the base and ones that only have the flat base with four screw holes - I recommend using the flat base ones. There is no real easy way to open up the bottom of the cabinet as it is glued and then covered with the tolex or similar material. If you have the ones with a shaft I recommend getting the other type. The shaft has a socket you have to install in the bottom which makes them removable. There is no reason to remove the casters so get the ones that are screw mounted.
