Microwave Ovens Logo
B
Bruce sunderville Posted on Jan 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave stopped heating in the middle of heating. Light and timer work. Just clicks when you try to heat. Owned 8 years never a problem.
Mathew
Level 2:
Sergeant:
  • Expert 182 Answers
  • Posted on Jan 17, 2019
Mathew
Expert
Level 2:
Sergeant:
Answers
182
Questions
0
Helped
55831
Points
622
Chances are at that age the magnetron has gone the way of the ghost (the high voltage microwave maker inside). This part cannot be serviced, sorry.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Dec 11, 2007
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 04, 2009
SOURCE: cookworks microwave not heating up
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for Cookworks.
Anonymous
  • 86 Answers
  • Posted on Aug 18, 2009
SOURCE: Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Anonymous
  • Posted on Nov 15, 2009
SOURCE: Sharp Microwave R-520L stopped working
My parents had the same problem. It turned out that a switch went bad. When you take the case off, there are 3 switches where the door latches. The bottom switch went bad. It is an Omron D3V-16G-3C25 switch.
Anonymous
  • 23 Answers
  • Posted on Mar 17, 2010
SOURCE: Emerson Model MWG9111SL Microwave not always working
ok i just opened mine up on counter and found that the white wire on the high voltage transformer had been loose and melted so i put a new female spade connector on and it works fine. i suspect that from a year of use and humm from transformer had loosen it and gotten hot thus loosing connection and getting dirty causing it to overheat and burn off plastic sheilding. easy fix!!!
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
2helpful
More than likely the magnatron has failed,it is the heating source for microwave and usualy has 5 year warranty so it would be worth calling company about this. They will hve service company repair at no cost to you.
1helpful
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
8helpful
GE microwave oven
Top In Microwave Ovens Experts
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
