Washing Machines Logo
robb robersons Posted on Jan 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AMANA WASHER FILLS COLD BUT NOT HOT WATER - Amana Washing Machines
pauly milburn
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 109 Answers
  • Posted on Jan 17, 2019
pauly milburn
Expert
Level 2:
New Friend:
Greenhorn:
Answers
109
Questions
0
Helped
31509
Points
352
Check your wash program selection check tap on at cupboard
5 Related Answers
Anonymous
  • Posted on Dec 29, 2008
SOURCE: amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Anonymous
  • 5 Answers
  • Posted on Apr 02, 2009
SOURCE: Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Anonymous
  • 6784 Answers
  • Posted on May 20, 2009
SOURCE: Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
Anonymous
  • 53 Answers
  • Posted on Jul 09, 2009
SOURCE: Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Anonymous
  • 1776 Answers
  • Posted on Jul 19, 2009
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
3helpful
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
1helpful
2answers
Hot water when cold is selected
""Selectedd cold / cold and machine fills with hot water.""
Is your machine a FAV6800A or FAV9800A? If it's one of those I Have specific info to troubleshoot in Service Mode.
We will go into Service mode and turn on the Hot and Cold water inlet valves from the console and make sure the correct water inlet valve opens and fills the machine...........Rich
and a p/n if you need to replace the water inlet valve assembly.
1helpful
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
2helpful
2helpful
3helpful
2answers
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
2helpful
4answers
Amana washer has no hot water - cold works fine
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
