Transmitter and receiver for speakers are paired ok. I have a bluetooth speaker that paired just fine with tv. Hursk 18 use to work but stopped. bought new one and have the same problem. Thanks for your help
SOURCE: panasonic BT100 & sh-fx67 kit surround sound not working
make sure you have speakers A and B on, sometimes that is the problem
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need. Set the output on the source unit to optical out. Connect the optical cable to the amp. Connect the speakers to amp. turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
SOURCE: Technics SA-DX930. I ran digital optical cable
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
SOURCE: S-Sir Sub Unit won't pair
I almost went out and bought a Sony HDMI cable but I tried something first and it worked me. I wrapped tightly the transceiver on the back of the main unit with aluminum foil and what do you know it fixed the problem. I guess since I was using a cheap HDMI cable the foil helped to shield out the interference. Sony HDMI cable $70.00 or aluminum foil 5 cents. Let me know if this works for you as well.
Brent
mevioradio.com
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
