I checked motor belt its fixed. I remove motor belt and then run washing machine on spin, then motor rotates, but when i put belt on it try to move but does not and gives humming sound. I checked red and blue cables on rectangular box beside motor , both cables are ok. some one told me its dear box problem some one told its washing machine kit needs to be replaced. i am in big trouble i have to do laundry asap. Please help me. Regards Anum
Motor is broken try cleaning bushes easiy fix
Testimonial: "when belt is off , motor works..."
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
SOURCE: Drum doesn't spin at all during wash or rinse.
TRY TURNING THE DRUM BY HAND IF IT DOES NOT MOVE YOU PROBABLY HAVE A BAD MOTOR IF IT MOVES VERY EASILY YOU HAVE A BROKEN BELT. IF IT MOVES WITH SOME RESISTANCE TRY CHECKING THE VOLTAGE AT THE MOTOR IT BE A BAD WIRE
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see
o circular lid there, turn it on anti-clockvise to open. All of the
water blocked will come from there, be careful. Look carefully that
there are some objects blocking the water draining. Then turn on the
machine on draining programme, the plastic rotor should turn fastly
when the machine is on. If it is not running, change the pump motor. If
it is running, but machine is not draining again you can understand
that there is an objeck stuck on the hose between drum and pump motor.
Lay down the machine on its rear facade, you will see a large and black
hose between drum and pump motor. When you remove it, you will see that
there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
SOURCE: I have a Tricity Bendix AW1000W. The drum will not
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
