Code P1266 on a HINO 700 can indicate a fault or issue with the injection control pressure system. Here are some steps to fix this code:
Check the engine oil level and ensure it is at the correct level. Low oil level can cause issues with the injection control pressure system.
Inspect the oil filter and replace it if necessary. A clogged or dirty oil filter can restrict oil flow and cause pressure issues.
Check for any leaks or damage in the injection control pressure system. Look for oil leaks around the high-pressure oil pump, hoses, or fittings.
Inspect the fuel injectors for any signs of damage or leaks. Faulty injectors can cause issues with the injection control pressure system.
If there are no visible issues, it may be necessary to use a diagnostic tool or scanner to further troubleshoot the problem. The scanner can read and interpret the error code and provide more specific information on the exact cause of the issue.
If you are unable to identify or fix the issue yourself, it is recommended to take the vehicle to a qualified mechanic or HINO dealership for further diagnosis and repair.
Keep in mind that these steps are general guidelines and may vary depending on the specific model and year of the HINO 700. It is always best to consult the vehicle's owner's manual or seek professional help for accurate and specific instructions.
no YEAR TOLD
post your country,
and full model of HINO, and sure K13c
then others with same RIG and country and year, can read their manual to you.
or ask HINO for your matching service manual
or ask here
Hello , From Hino PDF download on page http://diesel-art.com/manuales/hino_y13c.PDF
It appears that p141x codes are all to do with 'EGR' Exhaust Gas Recirculation area but not that exact code.
Sorry can't help more.
