The machine, all in one, not indoor/outdoor split type, will make beeping sound when something is wrong and stops working until it is turned off and turned back on. Some times the machine needs to be reset with the power on, covers removed, reset button inside on electronic mother board. The ice machine covers have instructions and information on beeping sounds.
time the cycle. if it is only running about 5 minutes and going into harvest, look for sump loosing water. Look at where the unit drains (like a floor drain) while the unit is running to see how much, if any water is draining. does not take much to make an early harvest. also, sump may not be filling up completely but with just enough water to satisfy the float.
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
I don't have the details on you machine but if I were going to trouble shoot this problem, assuming its a temperature probe I would power off the machine, remove the access panel and remove the temperature probe and check it with an Ohm meter or continuity checker for proper functioning by putting the probe in ice and see if it opens electrically. Sometimes the probe is not a simple thermostat type. The bin control on some machines is optical. The ice pile breaks a light beam to turn off ice making. Sometimes the probe is a thermistor. These latter two kinds of probes have electronics connected to them. A simple ohm check will not work for these cases. You can tell what kind you have by looking at it carefully. The thermostat kind that can be checked with a continuity checker or ohm meter is a sealed metal tube. The optical type has a light source and a separate pick up sensor. The thermistor type is a very small device on the end of a pair of wires. For the optical type or the thermistor type write back for more details.
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
check make sure water is turn on.
bin sensor stat might be open.
lastly on p.c.b board there is a rest button.
make sure ice thickness sensor is descaled and petrolueum
jelly smeared terminals of prons( if it a casade type)
