Exercise & Fitness Logo
Max Raber Posted on Jan 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hallo, my Marathon ST from Kettler stops working after 3 secounds with ER01. What can i do?
Reda Bigy
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Nov 09, 2021
Reda Bigy
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
394
Points
How can i test the speed sensor plleeease
Steve Cox
Level 3:
Master:
  • Master 674 Answers
  • Posted on Jan 18, 2019
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
212958
Points
1718
Check the code with Kettler's website in support.
5 Related Answers
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on May 06, 2012
SOURCE: Problem with Kettler Marathon ST, error 01 and not starting
adjust the speed sensor, see the diagram attached, clean, and tight the wires connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.l
After you did, RUN the software calibration for diagnose, troubleshooting,and fix it.
sincerely. GOD bless you
Anonymous
  • 3 Answers
  • Posted on Aug 30, 2009
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Anonymous
  • 5 Answers
  • Posted on Oct 08, 2010
SOURCE: Hi, I'm after purchasing a
Go to www.kettler.net look for global, click on global and it gives you a listing for Kettler distrubutors world wide who should be able to help you.
anupam19
Anupam Datta
  • 263 Answers
  • Posted on Mar 12, 2011
SOURCE: The running belt on my kettler marathon tx1
Use grease and check if any lock is there
Anonymous
  • Posted on Apr 04, 2012
SOURCE: hallo i have this marathon
What is the my cab brake clippers and the cab
Kettler Marathon ST threadmill stuck on blinking HR
If your Kettler Marathon ST treadmill is stuck at the blinking HR (heart rate) screen and is unresponsive to button presses, here are a few suggestions you can try to troubleshoot the issue:
  1. Check the safety key: Ensure that the safety key is properly inserted into the console. The treadmill may not respond if the safety key is not properly engaged.
  2. Reset the treadmill: Locate the power switch or unplug the treadmill from the power source. Leave it unplugged for a few minutes to allow the internal electronics to reset. Then, plug it back in or turn the power switch back on. This can sometimes resolve temporary glitches or errors.
  3. Inspect the console connections: Open the console cover and check the connections between the console and the rest of the treadmill. Make sure all cables and connectors are securely plugged in. Loose or disconnected cables can cause communication issues and affect the functionality of the console.
  4. Clean the console buttons: Over time, dirt, dust, or debris can accumulate around the console buttons, preventing them from registering presses. Gently clean the buttons and the surrounding area using a soft, lint-free cloth. Avoid using liquid cleaners that could damage the console.
  5. Perform a console reset: Look for a small reset button or hole on the console. Using a paperclip or a similar object, press and hold the reset button for a few seconds. This will perform a console reset, which may resolve certain software or configuration issues.
  6. Consult the user manual: Refer to the user manual or documentation that came with your Kettler Marathon ST treadmill. Look for specific troubleshooting steps or contact information for technical support.
Corsa ST 2700-7 bike C/R=1:8
I need a new computer for my Kettler Corsa St 2700-7 Bike C/R 1:8
Were can I order it?
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email [email protected] or www.kettler.co.uk
9helpful
2answers
Hi Rendra,
Try this:
Top Kettler Exercise & Fitness Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
