Irons Logo
k
kerry robinson Posted on Jan 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Morphy Richards 333020 Jet Steam Steam Generator Iron When switched on my iron will just spurt water out in quite large quantities.
Steve Cox
Level 3:
Master:
  • Master 674 Answers
  • Posted on Jan 18, 2019
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
212947
Points
1718
There is a bad seal on the water reservoir or the steam tank inside the iron.
1 Related Answer
Anonymous
  • Posted on Sep 08, 2012
SOURCE: MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
My Morphy Richards steam generator iron is intermittent with steam.
If your Morphy Richards steam generator iron is experiencing intermittent steam and you suspect a blockage in the hose, here are some steps you can take to address the issue:
  1. Check the water tank: Ensure that the water tank is filled with clean water and that the water level is adequate. Low water levels can affect steam production. If necessary, refill the water tank.
  2. Examine the steam settings: Verify that you have selected the appropriate steam settings on your iron. Some models have different steam intensity levels, so make sure you have set it to the desired level.
  3. Check for blockages in the hose: Disconnect the hose from the iron and inspect it for any visible blockages. Use a long, flexible brush or pipe cleaner to gently clean the inside of the hose and remove any debris or mineral deposits that may be causing the blockage. Ensure that the hose is securely reattached to the iron after cleaning.
  4. Clean the steam vents: Over time, steam vents on the iron's soleplate can become clogged with mineral deposits or fabric fibers. Use a cotton swab or a soft brush to clean the steam vents, removing any buildup that may be obstructing the steam flow.
  5. Perform a thorough descaling: While you have already used white vinegar for descaling, it's possible that there are still mineral deposits causing the blockage. Consider using a commercial descaling solution specifically designed for steam irons. Follow the instructions provided by the manufacturer of the descaling solution to effectively remove any scale or deposits that may be affecting steam production.
  6. Contact customer support: If you have tried the above steps and the issue persists, it may be best to contact Morphy Richards customer support for further assistance. They can provide specific troubleshooting steps or advise on potential repairs or service options.
Remember to always follow the manufacturer's instructions and safety guidelines when cleaning and maintaining your steam generator iron. If you are unsure or uncomfortable with any aspect of the troubleshooting process, it's recommended to seek professional assistance to avoid potential damage or injury.
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 24, 2012 • Irons
Feb 29, 2012 • Irons
1helpful
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
2helpful
2answers
5helpful
2answers
Morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
May 27, 2008 • Irons
Top Morphy Richards Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
love helping
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
