I had changed my 02 censor on my 90 civic and the engine light stoped comin on then lately i had to mess with the fuse box to run straight power to my runnin lights cuz it wouldnt work for sum reason then now the engine light is back on and it didnt come on untill i did this ...oh and i have no cat striaght 2.5 pipe haha
SOURCE: help
i have a 1996 grand caravan, and i have the problem of alarm going off too. I also do not have a keychain to turn it off. All you have to do is unlock the driver door or passenger door with a regular key, and that stops the alarm.
SOURCE: license's plate light stopped working even with new bulb.
It wouldn't be a fuse if that's the only light that's not working, I believe all of the parking lights are on the same fuse. It's most likely a bad ground or corrosion inside the socket where the bulb makes the electrical connection. So check the socket to make sure it has no corrosion, if it does, clean it up and apply some dielectric grease (available at any parts store) to prevent future corrosion, and check for a loose or broken ground wire.
SOURCE: 2007 Dodge Nitro Tail Light Replacement
look at the car manual under maintenance and then rear light bulb replacement. First take out the two hole covers using a flat head to loosen then wiggle and turn by hand to get out. Pull the light unit straight back, and unplug the electrical. Don't break anything.
Then use a star driver (check your misc socket set drivers for the right size). Unscrew the two star head screws and pull this bulb holder straight off the tail light (same direction as screws). Replace the bulb and put back together in reverse.
SOURCE: 02 RAM 2500 no power at trailer plug
It should have a fuse for the marker lights. Do they work on the truck. Brown is the color for the marker lights. Good Luck
SOURCE: I have a 02 dodge ram 1500 and the brake lights dont work
I've seen this more than once. Do you have a towing hitch? Sounds like you got a wiring problem with a trailer harness. If you do have a harness then check all the wires to be sure none rubbed through.
