Flashing red and blue on volume control
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
SOURCE: the volume knob is flashing red on my AX-SD1 amp..no sound.
Unplug the receiver, let it sit for a minute or two then plug it back in. It's either in "mute" or in Protection. Generally, Yamaha's will say "Ck. Spkrs" If it still has a problem, post a comment and I will look up some sources and help some more.
SOURCE: how do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
SOURCE: I am trying to charge
If headset does not charge and light blinks red continually, it is defective and will need to be replaced. It comes with a one year warranty. Call Plantronics at 1-800-544-4660 x 5538 for assistance.
Good Luck from Headsets Direct!
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
use the phone menu to search for Bluetooth
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
