Washing Machines Logo
Susie N Posted on Jan 17, 2019
I just bought a Kenmore washer that sences and uses less water .. can someone help me cause all it does it bang when it comes to spin cycle .. it shakes my house. It's supposed to balance it self out but it dont ... HELP !!!
Kenmore stackable washer/drier. Water doesn't drain out.
Kenmore stackable washer dryer doesn't cycle (doesn't advance to water fill or wash, drain, rinse, spin) (not spinning, draining, filling?) After the video, we learned it was the points in the timer. It wasn't the black "electrical plug", being plugged into. Get your serial number and google Kenmore timer and you can order a replacement timer. Even if you still have someone come out, you've still saved a bunch!.......ps....I had a viewer make a good point!; I obviously didn't have any issues, but obviously be careful with electrical panel and any loose wires!
2answers
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
2answers
Washing machine makes a loud whining noise when in high speed spin that it has not made before. Noise seems to come from the soap inlet tube.
usually when a front load washer starts making noise in the spin cycle it's not good,most of the time it's from the owner using to much detergent,it eats the spider gear and then it's time for a new washer,the gear costs around 500 bucks,next it will start to bang around and get real loud,i've seen the rubber boot get ripped off because it bangs all around,if you're using alot of detergent most likely this is the start of your problem,when you read the back of the bottle the measurements are for a top load washer not a front load so you better check that,also you could have a broken shock,also you can pull the middle of the pump out and check to see if there are any filings in there,i've seen that before.put it on high spin and listen to it,if it sounds like a knocking sound don't waste your money and call someone in,change out the washer and watch the cd that comes with it and use less detergent,i hope this isn't your problem but when the noise comes from the spin cycle it's usually the spider gear.
1helpful
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
Bosch Nexxt 500 is on rinse cycle, won't drain the water or spin
Hi
I would check two things that might cause this problem .
1. there is small palstic capsule that comes out from the tank and has thin rubber pipe that goes to the electric tap. the purpuse of the tube is to send signale to the tap to close the water , actually the tap has a sensor that sence the change in presure when the water tank is filled . check this capsule and make sure that its clean.
2.looks like the cycle of washing hasn't started or started but hasn't pass the stage of heating the water . that means there is some problem with the heater that lies in the buttom of the tank . make sure all wires attached properly .
try run whashing program of cold water .
consider replacing the heater .
hope it helps
goodluck
2helpful
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
2helpful
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Alexander
vince
