SOURCE: How do I change the oil in a Sears Craftsman MRS
Tip the mower up on it's side with the dip stick tube on the lower side and dump the oil out. Best to run the mower till its out of gas first.
SOURCE: Do all sears snow blowers fit on a craftsman lawn
yes and they will also fit ayp, husqvarna and poulan riders as they are all built by the same mfg. just be sure to get the snow blower that is for your modle tractor
SOURCE: Sears Craftsman lawn mower, 46
There is usually a sticker showing the drive belt route underneath the tractor right by the belts! If yours is missing I 'll try to take a pick of my tractors belt and upload it!
SOURCE: craftsman lawn tractor automatic transmission
Just like motor vehicles when transmission gets stuck on a particular place without moving forward or backward it is a sign of a jam in one of the transmission levers. This is usually caused by lack of transmission fluid in the gears.When the fluid or grease depending on what your unit uses gets low the levers begin to grind against one another and therefore bring about such problems as you are facing. Although there is an off chance that the problem could also be from the automatic selector in this case the damage might not be so much probably an electrical fault.
First get an expert to check the auto selector if it is in good shape. If it is then i am afraid the problem is from the transmission levers.
Hope this insight has been helpful?
SOURCE: Blades on my Sears Craftsman
It might be that a drive belt is too small and doesn't release. It would be where the power goes from the engine to the deck.May have to get bigger belt.
