I suspect that you are confusing things a bit.
The inverse sine, called the arcsine is a function defined in the closed interval [-1,1]. And so is the inverse cosine. Any value outside this interval will give you a non-real result (meaning a complex one).
There are no limitations on the domain of definition of the inverse hyperbolic sine or sinh^-1
If your input value is
allowed to be complex, the arcsine function gives a complex value. See the screen capture
