Exercise & Fitness Logo
Joey Macon Posted on Jan 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a precor eliptical 546 9A with no power. No lights come on the lower pca. I think I have power to it going to the lpca. Is there any way to confirm? Even with power the lights on the board should display right?
Steve Cox
Level 3:
Master:
  • Master 674 Answers
  • Posted on Jan 18, 2019
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
213021
Points
1718
Are you sure the PSU is functioning? Check it with a multimeter set for DC Voltage. Compare what it is putting out to what the factory specs are.
  • Joey Macon Mar 23, 2019
    Psu Looks good ..123 volts going into the lpca.
Joey Macon
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Mar 23, 2019
Joey Macon
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
227
Points
Getting 123 volts to the lpca.. not sure how to test past that. If I get a lpca do I match it to the serial number? Ive looked for the numbers on the lpca board and can't find.
5 Related Answers
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Jul 29, 2010
SOURCE: i am looking for a parts and repair manual for a
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
Anonymous
  • 79 Answers
  • Posted on Sep 07, 2010
SOURCE: where can I purchase a
review on gympart.com
Anonymous
  • 1040 Answers
  • Posted on Sep 08, 2010
SOURCE: I get an error message on my Precor EFX5.17
Error 54 - Target Pulses Lost During Operation... Description... This error is associated with the 5.17 EFX. This error indicates that at some time after the initial start up sequence was successfully completed, the gear motor was instructed to move and no response was seen from the motors revolution sensor. Possible Causes (1.) The F2 fuse is blown.... (2.) Damaged or Intermittent gear motor wiring.... (3.) Bad gear motor.... (4.) Damaged gear motor target... (5.) Bad lower PCA.... Possible Remedies.... (1.) Remove power from the 5.17. Remove the F2 fuse from the lower PCA. Measure the fuse with an ohmmeter. The fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the F2 fuse was blown there may have been a reason that will cause the fuse to blow again such as; damaged gear motor wiring or a bad gear motor..... (2.) Carefully inspect the gear motor wiring for intermittent or damaged wiring or connections. Replace or repair the wiring or connections as appropriate..... (3.) With power removed from the 5.17, remove both wires from the gear motor. Measure the gear motor resistance with an ohmmeter, it should read approximately 9 ohms. If the reading is significantly low or significantly high, replace the gear motor..... (4.) Visually inspect the gear motor target, if it is ripped, torn or badly scratched, replace the target..... (5.) Measure the voltage at the gear motor during the start up sequence, it should measure approximately 12 V.D.C. The voltage would only be present between the time the sequence was initiated and an error was displayed.. If the voltage is significantly low or absent and the F2 fuse is good (see step 1), replace the lower PCA......
Hope this has helped you.... Thanks...
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on May 14, 2012
SOURCE: tv flickerig on precore eliptical
Dear Sir:
You must test the power supply inside of TV, if you have skill for to do oit use DVOM, otherwise you must call some service tech, or go to repair shop.
However try to tight every connector wires, for loose, breake(test the wires for continuity) or burn.
God bless you.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 20, 2012
SOURCE: i am working on Precor 932i treadmill, not having any luck yet. I have found a load resistor ,100 ohm 50 watts burnt out. would this cause the treadmill not to power up?
Dear Sir:I am recommend you to exchange the board. If you do not have ENOUGH experience will be better to buy a new one, or call some tech profesional for to execute this delicate work.
The causes can be various, Maybe you have SHORT circuit in the motors, power supply, see the block diagram.
God bless you
Precor efx546i error 30
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
What is an error code 32 on a Precor 546I
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Precor error 12
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
2answers
What is error 30 on the precor 9.33i treadmill?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Error 30 on precor 546 efx
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Precore efx 546 error 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Error 30 for elleptical precor efx5.23
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
How to fix Precor EFX 5.17 error code 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
