Televison & Video Logo
Leslie Craig Posted on Jan 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony bravia 55" TV, the model # is kdl 65w850c with a part that came loose. According to the Service Manual I downloaded, it's called a BT antenna.
  • I am A smurf
    I am A smurf Jul 17, 2021
    that models a 65" television not a 55"
timoboon2
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Jan 17, 2019
timoboon2
Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154714
Points
959
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
5 Related Answers
Anonymous
  • Posted on Nov 23, 2008
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Anonymous
  • 4 Answers
  • Posted on Jul 08, 2009
SOURCE: tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Anonymous
  • 157 Answers
  • Posted on Oct 07, 2009
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Anonymous
  • 178 Answers
  • Posted on May 07, 2010
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Anonymous
  • 10594 Answers
  • Posted on Aug 29, 2010
SOURCE: manual for a sony bravia
Click Sony Support to download user manual free copy for KDL-32M3000
1helpful
NEED A USER MANUAL FOR A SONY BRAVIA TV MODEL KDL-40W5500 MODEL 9201533AN YOU HELP PLEASE THANK YOU
Sony has the manual for the KDL-40W5500 on the product support page: http://www.sony.co.uk/support/en/product/KDL-40W5500 . Scroll down to the Manuals section and there are two documents immediately shown. There are additional manuals stored on various Sony sites available, if you click on the link for all manuals. The direct link for one version of the manual in English is http://download.sony-europe.com/pub/manuals/swt/Z006/Z006062111.pdf .
I hope this helps.
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
1helpful
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
2answers
How do I find the user manual for KDL 32 ex 710
Hi
You can go to this Sony support site.Enter your country, model number.I was able to get the manual of my LCD TV (same model as what you have).
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
Thanks for using Fixya.
II need an oners manual ofr a 2010 sony bravada
Click Sony Support link to download KDL-40S2010 user manual copy or click Sony Support link and pt model number of tv to get required user manual.
Thanks.
I have a sony bravia 55 inch rear projection tv. model no. KF-55E200A. when i turn it on it flashes green like normal but then starts flashing red. can you tell me what is wrong with it please
Most probably it is an optical block issue. You can contact sony customer service to setup the free service.. If you need the contact infomation, please let me know where you're.
www.fixya.com/users/shajanrs
3helpful
2answers
Manual for a Sony Bravia TV
Here you are:
http://www.sony.co.uk/product/t32-nx-series/kdl-40nx703#pageType=manual
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
