Computers & Internet Logo
S
Steven wayne page Posted on Jan 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get past the BitLocker recovery on my Asus Zenbook Pro and have no way of getting the BitLocker recovery key cuz it was inherited how do I get this can I take the battery out and it be reset
Larry Ng
Level 3:
Top Expert:
  • ASUS Master 14,591 Answers
  • Posted on Jan 16, 2019
Larry Ng
ASUS Master
Level 3:
Top Expert:
Answers
14591
Questions
0
Helped
3277579
Points
66570
You can't.
ask the owner , did they pass on/?
all you can do is killdisk it
the reload the OS
by design, in fact.
read at microsoft.com how bitlocker works
answer :perfectly.
  • Anonymous Jan 28, 2019
    that is the prime purpose of that product
    100% security, to data
    it can be erased and the windows reloaded.
    most times.
    talk to ASUS.com yet?
5 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Nov 17, 2012
SOURCE: asus zenbook wouldn't start
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
maxcarson
max carson
  • 7627 Answers
  • Posted on Nov 21, 2012
SOURCE: how to enter bitlocker key on a cf-52 or a backdoor
You have secured the machine with a bitlocker key. inter the code to unlock.
TIPS72
DUSHYANT SINGH
  • 369 Answers
  • Posted on Jul 12, 2014
SOURCE: why does not my Full BitLocker Recovery Key ID:E443D361-OFAA-4301-97FC-CFEC7F735D9B WORK?
Please Check and type properly people normally skips some number or letters.
TIPS72
DUSHYANT SINGH
  • 369 Answers
SOURCE: i need a BitLocker Recovery Key identifation: E443D361-OFAA-97FC-CFEC7F735D9B?
Mail your company expelling your problem and they will provide you a new key.
Stan Ford
  • 3131 Answers
  • Posted on Jun 11, 2015
SOURCE: how do I do a factory reset on an Asus sonicmaster
Did you make a repair disc when you first got the laptop , have you made a recent back up , if so run the repair disc and instruct it to repair from the back source. A factory reset is done by a hard drive format and a fresh install. all data on the laptop will be lost. You could try systems restore and restore to a earlier date , If restore points have been made it should work.
My Asus ux430u is asking me for a paraphrase for hoe, gpt3
pricey Zenbook
$1k.
so under what conditions does this thing Hoe , out, with gpt3.
hoe = shovel out? (toss)
GPT3 is hard disk 3 GPT partition failure I guess.
the PC has some kind of corruption .
do the recovery steps in your manual>? asus.com
it's there.
tip
How to Recover Data From a Disk Encrypted by Bitlocker. Data Recovery.
Today we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where BitLocker stores important data, that happens due to unexpected system shutdown), inability to load OS or BitLocker recovery console, and other similar errors that prevent normal opening of the encrypted disk. The described problems may affect both system disk,portable external drive or USB drive.
In order to recover data we will use the utility Repair-bde (BitLocker Repair Tool), a command prompt utility which appeared back in Windows 7 / 2008 R2. This utility is used for access and recovery of encrypted data in a damaged disk encrypted by BitLocker.
Warning. This procedure should be applied after all the others have failed, and it was impossible to unlock the encrypted disk in a standard way by using a Bitlocker password or recovery key.
Requirements for data recovery from a BitLocker volume
To recover data from a disk encrypted by BitLocker you need to have at least one of the following Bitlocker defense elements:
  • BitLocker recovery password;
  • Recovery key;
  • System startup key (Startup key - .bek).
Data will be recovered to a separate disk the size of which should be no less than the size of the damaged disk. In the course of recovery, all contents of this disk will be deleted and replaced by decrypted data from the Bitlocker volume.
In our example, disk E: (size 2 Gb) is a USB drive the contents of which are encrypted by BitLocker, and which cannot be opened for some reason. To recover data, we have installed an additional external disk F: (size 16 Gb).
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-9.png
Method 1. Data recovery with the use of a BitLocker password
In the first place, try recovering data with this method (it will work with Windows 8 / 2012 and newer versions):
  • Launch command prompt as administrator.
  • Execute the command:
    repair-bde E: F: -pw -Force
    where E: - disk with Bitlocker data, F: - disk where decrypted data should be extracted.
  • In the course of executing the command you will have to specify BitLocker password (the same which a user is to enter into UI when trying to access an encrypted volume).
  • http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.png
Method 2. Decryption of a Bitlocker volume with a recovery key
For decryption of data located in a damaged volume which is encrypted with Bitlocker we will need a recovery key or a system startup key (if the system partition is encrypted).
Advice. BitLockerRecoveryKey is a unique sequence of 48 symbols. The recovery key is generated when a Bitlocker volume is created; it can be printed, saved as a text file to a local (this choice is not recommended) or external disk, or in a user account at Microsoft website.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.png
Now let us launch data recovery with the help of this key:
repair-bde E: F: -rp 011407-712393-682121-100210-377003-405174-520014-328130 -Force
If Bitlocker is used for encryption of the system partition containing Windows, and for loading the system a special startup key on a USB drive is used, the encrypted volume can be decrypted as follows:
repair-bde E: F: -rk I:\3F558473-943D-4330-8449-62C36BA53345.BEK -Force
where file 3F558473-943D-4330-8449-62C36BA53345.BEK is a key to launch BitLocker disk encryption on a USB drive G: (by default, this file is hidden).
After the procedure of data recovery and decryption, before opening the disk where the contents of the Bitlocker volume were extracted, it is necessary to run its check. In order to do it, execute the following command and wait until it is complete:
Chkdsk F: /f
Important note. If you failed to recover data from an encrypted disk with the described methods, it is worth trying to create a sector-by-sector copy of the damaged disk with the help of a Linux utility DDRescue (or any other similar utility). After that, try recovering data from the received copy by the following scenario.
Data Recovery Software
We also should notice that exist more common and simpler way to recover files from Bitlocker encrypted storage. These are data recovery software. Of course, not all programs ?an cope in such situation but some of them have required function.
The only thing is that you must have a password to unlock the device which was specified when encrypt.
Then it's simple. Connecting device with the information that you want to recover to your computer and getting message.
Further, enter password in a special window after double-clicking on the device you need to recover in "This PC".
After that, the storage becomes fully accessible for data recovery for any of the Hetman Software programs.
tip
In this article we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where
  • Recovery key;
Chkdsk F: /f
After that, the storage becomes fully accessible for data recovery for Hetman Partition Recovery.
https://hetmanrecovery.com/recovery_news/how-to-recover-data-from-disk-encrypted-bitloker.htm
4answers
My pc don't see my hard drive. Thought to go to some data recovery services, but here is the problem - this hard drive is encrypted and I don't remember the password
It's always a chance. It's hard but possible. It's will depend on what type of encryption is used and how did you "broke" the drive. If in some recovery service they say they can't do it , you should try at least few more, because I know for sure that it is possible . This guys definitely can do it - www.datarecovery.net - look, maybe there is office in your town.
Oct 16, 2018 • Cell Phones
How do I factory reset my surface pro 3? Please help!
Start your Surface by using a USB recovery drive. Insert a bootable USB drive into the USB port on your Surface, and then press and hold the volume-down button while you press and release the power button. When the Surface logo appears, release the volume-down button. For more info, see Boot Surface from a USB device. If you don't have a USB recovery drive, see Download a recovery image for your Surface.The USB recovery drive must be formatted to FAT32 (not NTFS) to work correctly.
https://support.microsoft.com/en-us/help/4023533/surface-restore-or-reset-surface
If you obtained the surface pro from someone else as you stated in your question, that bitlocker approach won't work, as you don't have their password. Go to a computer store, and ask a sales person or go to their tech support area to help you buying a USB thumb drive for less than $20, and how to set it up.
3answers
How can I factory reset my surface pro without bitlocker recovery and password?
I call microsoft about your surface pro and they should help, is your surface still under warranty
1helpful
3answers
Dell latitude laptop locked out with it asking for bitlocker password which I Don't have and i can't access my computer now
If you don't know the bitlocker password, forget getting access to your computer. Take out the hard drive encrypted by bitlocker, and install a new hard drive. Reinstall operating system on the replaced hard drive.
It will be a new installation.
When ca i get somebody to answer me about my surface2
Since the release of the latest Surface revs, problems are continuing to be reported where the Surface will boot into a screen that requests the BitLocker Recovery Key before it can continue. This issue was also reported with the first revision of Surface devices, however, it was not as widely reported as it is now.
This result can be caused by a wide range of things such as corrupted drivers or Windows Updates not able to install successfully. Whatever the reason, you'd like to be able to get past the BitLocker Recovery Key request screen, but have no idea how to locate this extremely long number.
Luckily, Microsoft stores this number for you in the Cloud. Using a working computer connected to the Internet, just jump out to the following link and ensure you are logged in with your Microsoft account.
https://skydrive.live.com/recoverykey
When you access this link, you'll something similar to below, except yours will contain the actual Key ID and abnormally long Recovery Key number.
The BitLocker Recovery Key is intended to add an additional level of security, ensuring that only the authorized owner of the Surface can unlock the device and restore access. Unfortunately, if you can't find your key, or your key does not display on the Microsoft account page, you'll need to restore the Surface to factory default settings, i.e., start over.
2answers
I can't access my Surface with my pin number. how do I access it now?
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
