Dryers Logo
Paula Hubbard Posted on Jan 16, 2019
Kichler uc7206t stopped working can't turn off fan or light.
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 01, 2018
SOURCE: Where is the reverse switch on my kichler model number UC7206T fan?
It would be just above the fan on the motor body
Kichler ceiling fan remote UC7206T works everything except won't change speed of my fan blades
you need to replace remote and receiver. receiver is located under ceiling canopy. refer to you installation booklet that came with fan.
Model #337001WH available at HD
2answers
Does a kichler ceiling fan remote model # uc7206t have reverse?
www.kichler.com/customer-service.aspx
Almost all ceiling fans have reverse. The switch is usually on the side of the fan so one must get a ladder to get to it. Air flow to be up in winter and down in summer.
Nov 14, 2014 • Dryers
2answers
Does a kichler model # uc7206t fan remote have reverse?
Surely the blades are formed to work only one way? To have reverse flow you would need to reverse the blade angle.
Kichler uc7206t
I don't think that's the correct fan number but if you look on the socket, it should have the wattage.
Jan 05, 2014 • Dryers
Kichler uc7206t
The model # should have 6 digits and 2-3 letters at the end.
Aug 04, 2013 • Dryers
1helpful
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Top Kichler Dryers Experts
john h
Steve Pack
Steve Pack
Mark Berger
Mark Berger
Are you a Kichler Dryer Expert? Answer questions, earn points and help others
