SOURCE: Pump problems?
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
SOURCE: Whisper Flo model WFE 6
Possible bad motor. You would need to test voltage at the motor connections with a multi meter. If the voltage is correct, then the motor or start capacitor is bad. If the proper voltage is not correct, then you would need to look upline in the electrical system to find the problem
SOURCE: have pentair easy touch controls just installed
If the Easy Touch is reading the correct temperature, but the heater is not - you need to double check the temperature of the pool water with a standard pool thermometer.
Other things to consider:
1) The water is traveling too slowly through the heater. If the water is heating too quickly, then it will shut it off. If it takes a while for this to occur, then this would not be the issue.
2) Thermostat/thermistor is incorrectly reading the temperature of the water prematurely shutting the system down.
Make sure you really are checking the temperature of the water and matching this temperature up with one of the two readings that you are getting. Don't just take the word of the displays on either unit.
Esse c?digo de erro ? falta de comunica??o entre a placa e o touch r14
