SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
SOURCE: DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
SOURCE: error codes
I get a 51 code on the treadmill, I think the relay is bad, Can I get parts for this? Pat please respond to [email protected]
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
SOURCE: E02 error and heater will not start. Service
high limit is open this is due several factors like slow water .pump on low speed or dirty filter, also hard water, or assembly valve not working properly so make sure the filter is clean check the water chemistry an last check the valve assembly. make sure plumbing is correct water in and out from the heater
