We have a Bosch SHU3036UC/U11 dishwasher that occasionally does not want to stop at the end of the rinse cycle. It continues to fill and drain simultaneously. I've not listened closely enough to see if this process happens throughout the entire cycle. The other day when the cycle was supposed to be complete, I pulled the door lever which shut the power off. The thing sure fills quietly because I came back a few minutes later to find water running across the kitchen floor. Obviously, the water kept running. I restarted the unit and it drained out. The unit finally stopped filling... not sure what I did if anything. I haven't used it since. Any idea how and where to start diagnosing the shutoff problem?
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
