SOURCE: Sharp AL-1641CS Lase Copier
Hi, red cylinder means the drum needs to be replaced, i wouldn't bother if it is not causing any issues. to cancel the light; cancel, exposure, cancel, exposure, 24, print, 07 print, cancel cancel, jobs a good 'un, 'appy days.
Andy
SOURCE: Problem with copier SHARP AR-206 display
what is the problem with the display ? is it out ? or showing an error ?
SOURCE: my copier AR-5320E is showing a number 4 and letter H
the fuser unit is not heating up
unplug the copier then plug back in
make sure the fuser area where you clear jams is latched down
close all doors
if this does not work your fuser lamp is burned out or a fuse has blown on the heater roller
You will have to call service
SOURCE: My copier sharp AR-5320E is
H4 is a fuser problem, normally a reset will cure, to reset press these buttons
#, interupt, cancel (c), inturrupt. Display should say 'enter simulation'
enter 14, start, execute.
Switch off then on and it should work
Cheers
