Video Game Consoles & Games Logo
j
jill cohen Posted on Jan 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My disc stops after a few minutes and says to check with microsoft support but that isn't helping
Giselle
Level 3:
Genius:
  • Microsoft Master 1,015 Answers
  • Posted on Jan 16, 2019
Giselle
Microsoft Master
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286541
Points
2407
Buy fast and cheap FIFA coins, fut coins, fifa 19 coins and fifa 19 ultimate team coins on https://www.fifacoin.com
I have a Sony DVD recorder player RDR-GX257. Player works fine. Disc recorder stopped working....
1. If your Sony DVD recorder player RDR-GX257's disc recorder has stopped working, don't despair! There are a few things you can try to get it up and running again.
2. First, check to see if the disc recorder is properly connected to your TV and to an electrical outlet. If everything is plugged in correctly, try pressing the "Reset" button on the back of the DVD recorder.
3. If the reset doesn't work, try unplugging the DVD recorder from the power outlet for a few minutes, then plug it back in. This sometimes clears any glitches that may be causing the problem.
4. If the DVD recorder still isn't working, it's possible that the disc itself is the problem. Try inserting a different disc into the player and see if it will play. If it does, the first disc was probably the issue. If the second disc doesn't play either, then the problem is most likely with the DVD recorder itself.
5. If you've tried all of the above and the DVD recorder still isn't working, you may need to take it to a repair shop or contact Sony customer service for further assistance.
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
2answers
After selecting disc it spins a few times then stops and ejects
Hello
The laser pickup unit is defective. Replace it with same type and number. OK.
My problem is, always my komputer stop working around 1-10 minute.
How do you mean? The software isn't functioning right? Check your power management settings. You may need to adjust as computer may be going into a sleep mode.
Hi everyone , I have a problem when my Hp dv 600 is turn on and windows failed to start . It's giving me 2 options to launch startup repair ( for this I need windows disc and I don't have it ) or to...
When one purchases a new machine, the very first thing that the machine prompts to do is make a rescue disc. If you haven't got one, you will need to either purchase a new OS disc or check you have the licence key on the underside of your notebook and if you have, borrow a system disc to rescue your system.
Hope that helps.
I need to find out how to stop this proplem
Does it do this for all games or just one disc in particular?
HP dvd1040i only recognizes discs for a few minutes.
it is the simple poblem of hardware you want to change your cd drive now
Microsoft FSX will not load on my new Vista PC
Hello hshames,
The game requires Windows XP SP2, or Vista..So that should not be the problem.
First install the latest version of Direct X which you can download FREE HERE.
Below is a small summary of what may be causing your installation problems.
This seems to be a problem some users are having.It seems to be either software related (other software not the actual software on the FSX disc itself), or hardware related (DVD drive not reading the disc properly).
To try solve this issue, follow these steps in order. If the problem is solved after step 1 (for example) you do not need to follow the instructions following that step. if not solved, move to the next step in the chain.
1. Some DVD readers can take up to 2 minutes to detect disc #2 (for reasons unknown). If the disc appears not to be detecting, just leave the computer for a few minutes and come back and check. Some users have reported that the disc #2 finally detects and installs correctly several minutes after inserting the DVD into the drive.
2. Manually browse the Disc #2 file contents in either Windows Explorer, or by accessing the DVD through the "My Computer" option and check the files on Disc#2 are actually different to those on Disc #1.
3. If you have the hard drive space available, copy the contents of both DVDs to a temporary folder on your hard drive, and install the product from the hard drive copies.
4. Read this Microsoft Tech article and follow instructions > http://support.microsoft.com/kb/290301
After trying the above suggestions, please post back with the status of your problem and any new info so I can be of further help.
Thank you for choosing Fixya!
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Dr-mh30s. stops dubbing after a few minutes.
I seem to have sorted this problem for me simply by unplugging power.
I actually left it for nearly a week before plugging in again, but I'm sure a day would do, probably less.
Dubbed 2 playlists since, no problem.
Nice simple solution if it works.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
