I just replaced a heavily damaged idler pulley and dryer belt because the drum quit spinning. Now the dryer buzzes at me when I try to start it, and getting it started manually produces a smell. Please help :(
Over the years I've found that if it buzzes but will only start when you "assist"it, the drive motor is at fault. The hot smell you describe backs that up.. This assumes the idler is ok and the belt is routed correctly. Make sure the belt is on the motor pulley and not riding on the motor shaft. This can happen sometimes if you have to install the belt by feel when you can't see it well . That said, the motor should still start without assistance even with an incorrectly installed belt.
Good luck
Bad motor.
SOURCE: idler pulley arm
there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.
SOURCE: serpentine belt slips off idler pulley
The A/C pully is supposed to spin freely until the AC is activated to run.. The cranshaft pully does not. Replace the tensioner pully. The belt has to fit in between the grooves on the pullys.
SOURCE: My dryer squeaks loudly when running. I have
Yes .I would say its the jockey pulley @ fault..
SOURCE: need dryer belt routing diagram for amana lea50aw
Yes, your right about the 93 3/8 length....
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=19414&diagram_id=694553#d694553
If you have a 95" belt it will not work, you got the wrong part...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
