Electronics - Others Logo
Larry Fudalik Posted on Jan 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My PDA6BU will not read my new PNY 64 GB 3.0 usb drive.
timoboon2
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Jan 16, 2019
timoboon2
Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154626
Points
959
Did you format it to FAT32 before you placed music on the card?
Testimonial: "It wasn't the format but the 64 GB size."
5 Related Answers
Coss
  • 1056 Answers
  • Posted on Sep 08, 2008
SOURCE: how do i remove the write protection on pny 8GB usb flash drive
Here is the answer from PNY.
http://www2.pny.com/support/support_single_faq_viewer.aspx?ArticleID=1415&RootSectionID=1057
Be warned, this is a low level format tool from them. What ever is on your flash drive will be erased.
I went exploring on these drives and found that when they start acting like they are write protected, it means that the drive corrupted. The low level format tool, will completely reformat that drive, and hopefully correct the problem.
They say it happens (usually) if you removed the drive from a computer, without using the safe eject USB function.
If this is a new flash drive, take it back to where you got it, and ask for a replacement.
sandy_s
Sandy Moore
  • 111 Answers
  • Posted on Sep 09, 2008
SOURCE: Deleted files from my PNY 4GB flash drive are still taking up space.
Most flash drive comes with its on date support files on it. If those had not been removed then, yes it will show some space used.
Anonymous
  • Posted on Feb 09, 2010
SOURCE: Kingston Data Traveler 2.0 64 GB USB - file system
2gb kingston pen drive showing capicity only 4 mb so pls provide the solution
AjayB
Ravindra Ravi
  • Posted on Jul 09, 2010
SOURCE: Samsung LA40C530 LCD USB limit
I have tested the LA40C530 Samsung with a 300GB external hard disk and it works well without any issue. My guess is that it should support 500GB as well. I have played video/music/pictures on my WD 300GB HDD.
Testimonial: "Thank Ajay, I will also try on a 500GB disk"
Anonymous
  • 64 Answers
  • Posted on Mar 06, 2011
SOURCE: Hi, I have a Sandisk Cruze
Do you have a legit copy of windows, sometimes if the copy is (Backup) then Windows will purposely disable drivers.
If, its a genuine version, first try plugging your usb device into another usb port somewhere. Try powering down your PC and powering it back on. If these steps do not work, go to Start>Contro>Driver/Devices and look if there is any Yellow caution signs with the device plugged in. If so, click on it and follow the steps prompted to find the appropriate driver for your USB device. It will do a search by itself.
Hope this helps-
J.Sper
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
The driver, it is not on my computer
USB Flash Drivers are an automatic install and so should work out of the box. If they aren't then can you try another flash drive? Can you also try and use another known working device in that same USB port? Is it the USB port that is damaged? Does the PNY work in another computer?
1helpful
I have a 64 gb usb drive for work and need to password it. Does pny offer this feature?
Right click in your drive select new folder Place all data files you want to password protect inside your new folder Right click on your new folder select properties select the sharing tab Scroll to network and sharing at the bottom You have many options to password protect many files and folders Windows 7 In XP right click on your folder select properties then click the sharing tab tick the box do you want to make this folder private A message might appear if you have a password do you want to create a password Or you might download one or more of these all are free password protection programs b> http://download.cnet.com/truecrypt/3000-2092_4-10527243.html True Crypt Free Encrypt your sensitive data with this open-source software. http://www.truecrypt.org/ for more information on this software
1helpful
How can i get my pc to read a sdhc pny 4 gb memory card ?
You need to get an SDHC to USB adapter. You can purchase one at Staples or any computer store.
I have 3 pendrive first & second pendrive of transcend & croma is not recognised pny 4 GB pendrive it shows (please insert a drive into F)
try using this software to format the transcend pendrive . use it in XP or Vista www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
I am trying to download a WMA Audiobook from the library site Wilbur, but it says that my PNY USB 2.0 FD USB device is incompatible
if it doesn t read your card. Its because the computer or labtop can not read HC high capacity cards. it will read a 1 GB or 2 GB but anything above will not be read. check on card if it has HC you need new hardware or a regular sd card.
How to get a driverfor pny 8 gb flas drive for
Then you will have to use a diskette or a CD, download the driver on some other computer, unpack and copy it to the diskette or burn on a CD-R.
Go to this link to download the drivers and for further reading on Windows 98 USB storage issues.
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
