Brand New Air Rifle- Shot 3 times only and can not **** barrel, seems locked even after repeating tapping end of barrel to unlock cocking of barrel.
SOURCE: Rifle sitting a long time but brand new won'thold air pressure
hi
contact Mac1 out of the US at [email protected].
He would be of help as he modifies these things and has full parts kits available.
or chek this link
www.mac1airgun.com
they sell you the o-rings or customize your gun to another level .
or chek some useful sites
http://www.crosman.com/airguns/service/manuals/crosman-rifles
http://www.fotolode.com/images/Rapidfirex/crosmanpumpmaster760assembly.jpg
hope u will b helpfull
regards
SOURCE: Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
SOURCE: Hi, I received a Crosman
Hit the top of the barrel with your hand. Don't be afraid to give it a good whack.
