Computers & Internet Logo
R
Robert Rieck Posted on Jan 15, 2019
I time out so am not able to any puzzles why?? I click on the Icon and it opens and then it shuts down and it takes me back Tony main page??
5 Related Answers
Anonymous
  • 4889 Answers
  • Posted on Mar 22, 2008
SOURCE: The shutdown window keeps coming up and my computer shuts down
This is probably due to a virus.. there are many viruses that do this.. Until you fix it you can open
gpedit.msc -> computer configuraton -> windows settings -> security settings -> local policies -> user rights assignment -> shut down the system -> remove everyone from shutting down the system.
This wont let anyone including you shut down the system including you but that would keep the system on until you fix the problem. I will check for the virus that does this and post back..
Anonymous
  • 2785 Answers
  • Posted on Dec 17, 2008
SOURCE: Mouse works, click on icon, nothing happens
its seems your os is havening problem try to restore to earlier date or repair it.
Anonymous
  • Posted on May 03, 2009
SOURCE: iphone not going back to the home page
By default, the home button will just close the open application and show the last displayed set of favorites (not necessarily the first page of favorites).
One option for you would be to set the double tap option for the home button to take you to the first page of favorites. By default, the double-click will show you your Phone Favorites, but this can be altered as follows: Choose Settings - General - Home Button. Then choose "Home" as the double-click option.
Hope this helps.
Anonymous
  • 25 Answers
  • Posted on Jan 29, 2011
SOURCE: After I install Hoyle Puzzle & Board 2011 on
haha
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 02, 2011
SOURCE: every time that i click on my favorite icon,my
Hi, when this happens it usually means the operating system is corrupt, the best thing to do is to reflash your Archos, you obtain the required software and then plug into the USB port and then using the proprietary software to reflash the internal memory on the Archos to replace the operating system, and restore it to functionality, if you ONLY copy over the system files you will keep all you old settings.
You need to go to the Archos website to obtain the Firmware also there is s "How to" reflash your Archos 7.
http://forums.techarena.in/operating-systems/1150953.htm
Above is a "How To" link...
www.archos.com/support/support_tech/firmware.html?...g... -
Support link above.
1helpful
How can I reset the tablet to factory settings?
hi if youre tablet is working open up youre icon page find settings or tools click this on it should take u to a page with a lot of info about youre tablet scroll down there should b (back up & reset) click on this & follow instructions good luck
3answers
you have a virus, scan your pc with nod32, you can download from www.nod32.com
Sergio
GA-81945GZME-RH alarm then shutdown
Gigabyte Support > GA-81945GZME-RH mobo > Main Support page,
[MOtherBOard ]
http://ee.gigabyte.com/products/page/mb/ga-8i945gzme-rh/
Click on the Downloads tab.
(Advantages / Overview / Specification / Downloads / etc)
To the right of - Download type: - click on the blue Down Arrow.
Click on Manual in the list.
To the right of the English heading, click on the country name nearest yours.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country name it may take up to 30 seconds, before the first page comes up.
Hover your mouse cursor towards the Bottom/Middle. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When your mouse cursor is on it, "Show Adobe Reader toolbar" will briefly appear )
You may have to increase, or decrease the view size.
Use the Zoom Out icon ( - ) at Top; to decrease.
Use the Zoom In icon ( + ) to increase.
Page 39 - 2.4 Power Management Setup
Scroll down a little;
Resume by Alarm
"You can set resume by alarm to be enabled, and key in Date/Time to power on system.
Disabled -> Disable this function. (Default value)
Enabled -> Enable alarm function to POWER ON system.
If Resume by Alarm is enabled,
Date (of month) Alarm: -> Everyday 1-31
Time (hh; mm; ss) Alarm: -> (0-23) (0-59) (0-59)"
Regards,
joecoolvette
2helpful
M935DLU motherboard manual
PC Chips Support > M935DLU > Main Support page,
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?DetailID=256&CategoryID=1&DetailName=Feature&MenuID=45&LanID=0
Under the red Downloads subheading, click on Manual
Scroll down. At the bottom of the page click on the NAME of the country nearest yours.
A small window will come up on the right -
Opening 935ds20a.zip
Make sure there is a Green dot in the small circle, to the left of Save File.
If not; click in the small empty circle to the left of Save File.
Go below in the small window, and click on OK.
Allow the file to download all the way. (935ds20a.zip)
DOUBLE-click right on the file name.
On the left side of the next small window, click on - Extract all files
At the bottom of the next three small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file's name, next to the red Adobe PDF icon.
(935D(v2.0A)
There is your motherboard manual.
Zoom In icon ( + ) at the top, increases the view size.
Zoom Out icon ( - ) decreases the view size.
Click on the blue Bookmarks icon on the left side. Second icon down.
Scroll down for English.
Mainboard Components illustration is on Page 23.
(Adobe Reader page number box at top. Not actual manual page)
Jumper settings on Page 27
Front Panel header (SW1) pinout on Page 28
Front Panel USB connector pinout on Page 30
For additional questions please post in a Comment.
Regards,
joecoolvette
I have a new computer that was just set up today. Ech time I go into say, my facebook page, when I try to go back to home, it takes me someplace else. I get frustrated and just shut that screnn, go to the...
Make it a favorite and then copy and paste that favorite icon to your desktop. make the favorite by holding the CTRL key and hitting D. Then open your favorites, right click on the icon and click COPY and then minimize the window and RIGHT CLICK ON THE DESKTOP and click PASTE.
Installed sucessfully the hp laserjet 1018 printer but can't prind any page.
If you're using a Windows based computer, you may follow the steps below:
1. Go to the Control Panel and double click the "Printers" icon.
2. Look at the HP Laserjet printer icon and make sure that the status is ready.
3. If not, right click on the printer icon and click on "Use printer online".
4. Right-click on the printer icon again and select Properties.
5. Click the "Print a test page" button under the general tab
If the same problem occur, check the printer manual and make sure that the printer is compatible with the OS of your computer. And be sure that you install the right driver of your printer to the computer.
Lastly, you may try to uninstall and re-install the printer driver.
Thank you and good luck!
Can't find puzzles 94 - 100 help!
Check out the illustrated walkthrough's puzzle index down the right (just click on the link of the puzzles you want) ... you may have to look back a page or two (there's a previous link at the end of each page) if you're not in the right place
http://professorlaytonwalkthrough.blogspot.com/
1helpful
How do i correct my yahoo name -- it is sent as max coalson and i need to change it to tony coalson///
Hi Tony,
1. Login to your yahoo email account. You will be seeing an "Options" link at the upper right corner of your page. Click on that.
2. It will open you the General page. Just replace the name on the "From Name:" field with Tony Coalson.
3. Click on "Save Changes".
That's it!. Your Name has change and the next time you send message, it will appear From: Tony Coalson.
I hope this helps you. Good luck!
Sep 26, 2009 • Yahoo Mail
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
