You need to replace the handle. Most single-flush toilets have a handle that covers a plastic piece that includes a stem that goes through the bowl. The stem is functions as a bolt held by a plastic nut on the inside of the bowl. When the handle falls off, that stem has broken. If the bowl lid is accessible, you can remove the lid and use the chain to flush the toilet. Dual flush toilets also have a plastic stem or tube that goes through the bowl.
Depending on your toilet, a universal toilet lever replacement may work. These are available at most hardware stores for under $10. For some brands, you may need a brand-specific lever. In a few cases, the part may not be available at hardware centers but is available through plumbing suppliers, plumbers or the manufacturer.
I hope this helps.
(Note: the nut inside the toilet bowl uses a left-handed thread. This is the only case in plumbing where it's lefty to tighten and righty to loosen.)
SOURCE: toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
