I’m replacing the blower wheel and cannot keep the motor from spinning when removing the old wheel.
SOURCE: installing blower motor on a 2000 alero
its on the bottom passenger side of the dash on the theres a plastic panel held by clips
SOURCE: replace blower motor
check out http://forums.audiworld.com/forum
tons of help to be had there.
SOURCE: hoe to remove the ignition switch in 05 ram 1500
Step1 Disconnect the negative battery cable from the terminal on the battery. Remove the upper and lower steering column covers by unscrewing or unclipping them. Step2 Remove the steering wheel by lifting off the center cover, disconnecting the horn wire and removing the retaining nut and washer. Make a mark on the steering wheel spline and the wheel itself so you can line it back up precisely. Pull the steering wheel straight back to remove from the shaft. Step3 Take off windshield wiper and turn signal switches by pulling them off as you did the steering wheel and disconnect the wiring. Slide the spacer sleeve off of the steering column. Step4 Unscrew the ignition switch mounting screws. Pull out the ignition switch. Disconnect the wiring connector from back of the ignition switch. Simply loosen the tabs and pull it out. Step5 Insert your key into the ignition. Turn the ignition switch to the locked position. Depress the retaining pin with a small screwdriver and turn the key to the Off position to free the cylinder. Once it is free, turn the key to lock position and remove the key and key cylinder. Step6 Install your old key cylinder into the new ignition switch assembly. Make sure the contacts in the cylinder and assembly line up. Reattach wiring to ignition switch, slide it into place, screw in mounting screws and reassemble steering wheel and switches.
SOURCE: How do I remove and replace Corolla 2006 blower motor?
Well the blower motor is underneath the dash on the passenger footwell, you have to remove the glove compartment to gainaccess to the blower, it ahas 3 or 4 bolts holding the motor, remove and replace with new unit, it is a good idea to replace the filter once the motor is removed.
