Wait 48 hours
Herbicide is absorbed through the plant leaves
http://www.herbiguide.com.au/Labels/FLU128_58521-0806.PDF
Mentions 48 hour period
Mentions avoiding windy conditions and spraying in dry conditions.
does not poison ground it affects what it comes in contact with.
wear gloves !
take about 1 week to kill couch grass
Testimonial: "Good advice given"
Thanks Brett. I won’t be planting them for another two weeks. I have set up retriculation and getting everything ready for them. I will spray the couch in the next day or so once the ground is wet. It is summer here and the couch will grow with the water on it
One more thing Brett. The instructions say 1.65L/h do you know what that would be for a 15 litre knapsack...
SOURCE: Danger of roundup applications around tree and bush plantings
Hi , I would be very carefull around good plants. Roundup will kill almost any plant, including aquatic plants, so you want to be sure to avoid spray drift onto other plants or into water.
SOURCE: growing indoor avocado tree from seed
Make sure it doesn't stand in water, don't give it too much. Moist is OK, but it needs to all drain out. Also, don't let soil cover the top of the seed area. Mulch on top is OK, but not right over the base.
Testimonial: "Thank you for your answer. I will repot this into a pot that has better drainage and I will clear the covering from around the "trunk " where it goes into the dirt.I am confident that you have solved this problem for me because I had over watering problems in the past. I don't know why I did not match these two incidents together and solve the problem before it became this critical. I will let you know my results - in about two weeks - if I can ever find this site again. I am not too good with computers. When I was a child I drank too much water. I appreciate your answer. - Lester"
SOURCE: If I spray on a weed that's in a flowerbed will it spread to harm some of my plants?
Hey Mary.. take a old deep bowl and mix a little weed eliminator in it and use a paint brush to apply to the weeds... this will eliminate over spray...
(I do this)..
please mark as helpful.. and follow me.. thanks
