>Menu >TV settings >Time Would be the most obvious way to update the time and date for my Element HD Smart TV. It's listed at the very bottom on this option screen but it's not highlighted thus not allowing me to change it. So, question..how do I change the date and time?
SOURCE: Date/time stamp control in Menu won't allow access
In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
SOURCE: date stamp option in menu
For some cameras this option only works when the camera is set to a specific resolution. Some calle this resolution "Postcard" resolution, and is usually 1200 pixels width. Try setting your camera to its other resolutions to see if this ocrrects the problem. Suggest that you start with 1200 x 900 resolution. Keep in mind that this 1200 x 900 gives only 1 megapixel resolution. Most newer cameras are capable of taking much higher resolution pictures, so this may be a trade-off if you want to use the date stamp option.
SOURCE: How to set the time on the 2006 CLK 500 instrument panel?
the operators guide, covers this. the dealer has it.
put it back on glove box for next time change. (yes, i too forget every year, too many cars etc)
