The kids have been using it but now the plug to the drain is missing where can i buy a new one thanks
If for a kitchen sink, measure the depth of the cup and diameter. Most hardware stores sell replacement stoppers.
If for a bathroom sink, look at faucet manufacturer and look online for replacement part.
For a quick fix for both / need a solution now to plug the sink, I have used in the past Saran Wrap is a pool plug rubber stopper that comes in a variety of sizes and fits both kitchen sink (larger one like size 10 or 11) or bathroom sink (size 6 or 8).
SOURCE: Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
SOURCE: Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
SOURCE: 1999 volvo v70 oil change questions
You can buy a canister wrench at the local auto parts store. You do not need to torque the oil filter on, just hand tighten, No new gasket for the drain plugs just do make sure that it is tightened properly
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
SOURCE: Plugged air conditioner drain on 2004 Porsche Cayenne causes leak
do you have also water inside the car??
