The clutch plate is probably stuck. If you have a clear space in front of the truck select first gear, release the parking brake and start the engine with your foot on the clutch. The vehicle will lerch forward and the engine should start with the vehicle now moving forward. Hit the brakes with your left foot still on the clutch and the clutch will probably release and work normally.
Check flyweel
Testimonial: "Thank You Clutch was stuck to flywheel"
SOURCE: i have an MGF 1.8
One of the improvement for Lotus Elise was the power (hydraulic) 5 speed manual clutch (something like power brakes) to make car to provide the faster responce. Thats probably wthat you have where
You might need to adjust it, replace the fluid or in a worsest scenatio to rebuild/replace the clutch.
Good Luck
SOURCE: my audi tt quattro 2004 model yesterday stopped changing gears
Release bearing problem.Change the clutch Assembly
SOURCE: Isuzu Trooper Clutch Pedal Issue
either it is a clutch fluid line busted (most likely)or its you clutch master you can start it anyway give a little gas in 1st and start it shut it off b4 starting i drove my volvo 740 home like that once nerve wrecking but save towing money
SOURCE: I lost tension on my clutch pedal on my 97
Sounds like a bad master cylinder or a throwout bearing that has gotten strange on you. (I'd know right away if I was there) Definitely don't drive it like that...you can damage the synchros in the transmission if you do. Also check the slave cylinder if it's not part of the throwout bearing...It also could have a problem.
