Konica Minolta Minolta Bizhub C253 Copier Logo
Joseph Posted on Jan 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Helo, this code C2151 is showing in my Konica Minolta bizhub c253. please how can I cancel the code. kindly help please.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Oct 21, 2022
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910507
Points
11959
When you open the right side door and look down at it you see a sponge looking roller. That is called Second transfer roller. The paper will go between that roller and transfer belt the shinney belt inside the machine it aligns with. During operation the roller should retract. There is a senor and motor that work together to execute the procedure. You will have to remove the assy. to get to the motor and sensor if its not them its the main board serious buckets and I doubt you can get one.
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: What does the errorcode C-3723 on a Konica minolta
C3723: Fusing abnormally high temperature detection (pressurizing side)
Anonymous
  • 158 Answers
  • Posted on Nov 16, 2009
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Anonymous
  • 44 Answers
  • Posted on Sep 06, 2010
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
What is solution to Trouble code C-0210 on bizhub C253
ensure no paper behind the paper trays
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
When my konica minolta c280 gives me an error codes c2151 please help"
Code
C2151
Description
Secondary transfer roller pressure welding alienation
• The pressure welding alienation sensor doesn't turn OFF (retracting) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is retracting. • The pressure welding alienation sensor doesn't turn ON (pressuring) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is pressuring
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
1helpful
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
1helpful
2helpful
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
2helpful
What is error c-2527 of konica minolta bizhub c253
sorry, cannot find that error code in SM. Are u sure is it correct code?
3helpful
3answers
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
